Lancool First Knight Case range - In stock now!!!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
We have the First Knight range of cases in stock now! These are effectively Lian Li cases but made from Steel. Offering the same quality, design and functionality but at a fraction of the price.
Lancool First Knight K56 Tower Case - Black @ £54.98 inc VAT
The look of Dragon Lord K56 has no door panel design users can access the external drive easier. two red stripes front done in attractive anodized aluminum give a flamboyant finishing touch to this outstanding high-end chassis.
- Dimensions: 210mm x 460mm x 490 mm (W x H x D)
- Front bezel Material: Plastic
- Color: Black
- Side Panel: SECC Steel
- Body Material: SECC Steel
- Net Weight: 8.85kg
- 5.25" drive bay (External): 5
- 3.5" drive bay (External): None
- HDD bay: 4
- Expansion Slot: 8
- Motherboard: ATX / M-ATX
- System Fan (Front): 120mm Fan x 1
- System Fan (Top): None
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB 2.0 x 2 / HD+AC97 Audio
Only £54.98 inc VAT.
ORDER NOW
Lancool First Knight K59 Tower Case - Black @ £69.98 inc VAT
The PC-K63 First Knight series gaming case builds LanCool’s high standard of Quality requirement. This SECC steel cases with completely tool-less design are the perfect complement to a PC gamer’s needs.
- Case Type: Mid tower chassis
- Dimensions: (W) 215mm x (H) 530mm x (D) 530mm
- Net Weight: 10.16KG
- 5.25" drive bay (External): 3
- HDD bay: 3.5” HDD x 6 / 2.5” HDD x 4
- Expansion Slot: 8
- Motherboard: ATX / Micro-ATX / Mini-ITX
- System Fan (Front): 140mm Fan x 2
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / e-SATA x 1 / HD Audio
Only £69.98 inc VAT.
ORDER NOW
Lancool First Knight K63 Windowed Tower Case - Black @ £94.99 inc VAT
- Color: Black ( Internal Black )
- Side Panel: SECC Steel side panel with transparents window
- Net Weight: 10.4KG
- Expansion Slot: 8
- System Fan (Front): 140mm LED Fan x 2
- System Fan (Top): 140mm Fan x 2
- System Fan (Rear): 120mm LED Fan x 1
Only £94.99 inc VAT.
ORDER NOW
I also see you have the K62 in Red back in stock , the K62 really are sweet looking cases.
Lancool Dragon-Lord PC-K62 Mid Tower - Red Dragon Windowed Edition @ £86.78 inc VAT
The Dragon Lord K serires builds LanCool’s high standard of Quality requirement. This SECC steel cases with completely tool-less design are the perfect complement to a PC gamer’s needs. The cutting edge tool-less design is an important key feature in the new LanCool cases. The LanCool design team considered end user requirements, especially home-builders allowing for faster component swapping. The new internal layout has the motherboard on top of the power supply unit, which allows for easier access to the motherboard as well as more room above, thus larger CPU coolers can be used. The power supply unit at the bottom of the case is cooled with fresh cool air directly from the outside of the case. The Dragon Lord K62 uses large size cooling fans to remove the system heat faster and quieter as well as keeps the system more stable. The interior has a great red finish which looks stunning which is showcased via the great looking clear side window.
- Motherboard Compatability: ATX & M-ATX
- Side Panel & Body: CECC Steel
- Front Bezel: Plastic
- 5 x 5.25" Drive Bays
- 4 x 3.5" Drive Bays
- 1 x 140mm Red LED Front Fan (included)
- 2 x 140mm Top Fan (included)
- 1 x 120mm Red LED Rear fan (included)
- I/O Ports: 2 x USB2.0 & 1 x Audio
Only £86.78 inc VAT.
ORDER NOW
It is a very good looking case, very sleek, if I was going to buy a case I'd probably go for that red K62, even over the 650D which I was going to get.
But then again, I think red and black goes perfect together.
