- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Hi
We have the First Knight range of cases in stock now! These are effectively Lian Li cases but made from Steel. Offering the same quality, design and functionality but at a fraction of the price.
Lancool First Knight K56 Tower Case - Black @ £54.98 inc VAT
The look of Dragon Lord K56 has no door panel design users can access the external drive easier. two red stripes front done in attractive anodized aluminum give a flamboyant finishing touch to this outstanding high-end chassis.
- Dimensions: 210mm x 460mm x 490 mm (W x H x D)
- Front bezel Material: Plastic
- Color: Black
- Side Panel: SECC Steel
- Body Material: SECC Steel
- Net Weight: 8.85kg
- 5.25" drive bay (External): 5
- 3.5" drive bay (External): None
- HDD bay: 4
- Expansion Slot: 8
- Motherboard: ATX / M-ATX
- System Fan (Front): 120mm Fan x 1
- System Fan (Top): None
- System Fan (Rear): 120mm Fan x 1
- I/O Ports: USB 2.0 x 2 / HD+AC97 Audio
Only £54.98 inc VAT.
ORDER NOW
Lancool First Knight K59 Tower Case - Black @ £69.98 inc VAT
The PC-K63 First Knight series gaming case builds LanCool’s high standard of Quality requirement. This SECC steel cases with completely tool-less design are the perfect complement to a PC gamer’s needs.
- Case Type: Mid tower chassis
- Dimensions: (W) 215mm x (H) 530mm x (D) 530mm
- Net Weight: 10.16KG
- 5.25" drive bay (External): 3
- HDD bay: 3.5” HDD x 6 / 2.5” HDD x 4
- Expansion Slot: 8
- Motherboard: ATX / Micro-ATX / Mini-ITX
- System Fan (Front): 140mm Fan x 2
- I/O Ports: USB 3.0 x 1 / USB 2.0 x 1 / e-SATA x 1 / HD Audio
Only £69.98 inc VAT.
ORDER NOW
Lancool First Knight K63 Windowed Tower Case - Black @ £94.99 inc VAT
- Color: Black ( Internal Black )
- Side Panel: SECC Steel side panel with transparents window
- Net Weight: 10.4KG
- Expansion Slot: 8
- System Fan (Front): 140mm LED Fan x 2
- System Fan (Top): 140mm Fan x 2
- System Fan (Rear): 120mm LED Fan x 1
Only £94.99 inc VAT.
ORDER NOW
- Color: Black
- HDD bay: 4
- Expansion Slot: 8
ORDER NOW
- Expansion Slot: 8
ORDER NOW
- Expansion Slot: 8
ORDER NOW
