Im just wondering, how long does my SATA cables need to be from my Optical drives. At the moment I have 30cm cables, I'm guessing they would be too small to reach the sata slots on my MOBO and go through the back of the mobo for cable management?
The straight line measurement from Optical Drive to Motherboard (optical drive in top bay) is about 20cm (couldn't get a perfect measurement because computer is still running)
So I'd imagine 30cm is fine with cable routing included....
Put it this way, I'm using the standard cables that came with the MoBo...
If you already have 30cm, wait and see, but I'm pretty sure it should work..
