Lancool K62
29 Nov 2009
Hi, I was wondering if anyone has watercooled a Lancool K62
I have a couple of these for my machines & would rather watercool these than get a new case but seems to be an issue unless some modding has went on
I was looking at the XSPC Raystorm starter kit but the Rad look too thick for the top but the Stealth one people have used give rubbish cooling
Any thoughts?
I've watercooled one before. There's room in the top for a 30mm rad - I used a Magicool 280 rad up there with the fans on the inside of the case. That requires some modding but you can fit the rad on the inside and fans in the roof compartment with no modifications.
You're probably best off using a 280x30mm rad up top if you don't want to mod your case much. That'll be plenty of rad space for a CPU loop.
