Guys,
Ive had a Lang D5 Vario pump MCP655 for few years now and its amazing. Having just purchased a Aquaero 5 LT, i would like to use this to control it.
My pump has a little dial to change the revs/min but I want to control the speed automatically, not manually.
Is it possible to change the revs/min by changing the voltage rather than with the little dial? It says it has a operating voltage of 6v to 14v and runs at 12v. So, if i reduce to 6v, will it slow down?
Rather check before frying £60 worth of pump.
Thanks
Rich
Thanks
Rich
