Lanyard for Bluetooth earbuds?
6 Jan 2012
Looking at getting some Bluetooth earbuds (open to suggestions, at the moment JBL reflect flows are the front runners) to replace the skull candy Ink'd wireless headphones I had. Unfortunately after 3 years of almost daily service they gave up the ghost, the weak link (like most headphones) being the wire linking the two earbuds together, alas my diy skills were not up to the job to patch in a new bit of wire due to the teeny tiny gauge they use...
Had originally wtlritten of the air-pod style earbuds as a fad but quite tempted by them as it should remove the weak link of the wire and the additional charge from the cassany of them provide is handy too. My only issue with them is the. Risk of taking a spill while skiing or out in the hills and losing them.
That's why I'm wondering if they is an effective earbud:lanyard/bit of string combination that won't interfere with the fit? As having it looped round back of neck is more likely to keep them attached to me and even if they do travel some distance it should be easier to spot a pair of them joined by a neon coloured bit of string/plastic. Had a quick Google and found some ebay specials lanyards but from the pictures it looks more. Like something to hang them from when not in use rather than join them together/attach them to me.
Thanks for any help offered with this odd request.
