silentphoenix said:IS that without being lapped? If so thats an absolutely awesome finish, but if its been polished, then you've done a bad thing...
squiffy said:The bottom on my Ninja is pretty ridgey, what is the realistic difference in temps before and after lapping? My cores don't exceed 50 degrees.
I think he means it looks too shiny to be a simple lapping. If you're lapping properly, all the way down to the tiny grits you might get it that shiny (no personal experience, so I dunno). silentphoenix is implying that you've added something else to polish it up, which is going to make it worse at transferring heat. Ideally, lap away metal until it's as smooth as possible (not necessarily shiny) and add tec to fill any remaining space.silentphoenix said:IS that without being lapped? If so thats an absolutely awesome finish, but if its been polished, then you've done a bad thing...
joeyjojo said:I think he means it looks too shiny to be a simple lapping. If you're lapping properly, all the way down to the tiny grits you might get it that shiny (no personal experience, so I dunno). silentphoenix is implying that you've added something else to polish it up, which is going to make it worse at transferring heat. Ideally, lap away metal until it's as smooth as possible (not necessarily shiny) and add tec to fill any remaining space.
There was a really pedantic thread a while back about how to lap "properly"...
