After Lapping my CPU (Q6600) and cooler (Tuniq Tower 120) today I was amazed with the results (especially considering the Artic Silver is fresh on so should get even better)
The best OC which was Prime 95 stable previously was 3.2Ghz (356x9)
I can now stably run 1.5+ volts with the temps staying below 75C in Prime95. Anoyingly I haven't managed to get 400x9 stable yet - but I will oh yes.
Currently I have managed 389x9 = 3500 ish with 2 full loops of blend Prime 95 with temps never going above 65C.
For anyone in the UK planning a lapping job I managed to get fine wet/dry from halfords.
The technique I used was -
CPU - Started at 600 Grit with the sand paper taped to a sheet of glass (taken from an old picture frame). Rubbed the CPU up and down 30 times - rotated 90degrees and repeated (rotating 3 times). Did this again on the same grit paper (so twice @ 600 grit and for each subsequent).
Then moved on to the next grade up - in all I used 600, 800, 1200 and 1500 paper.
Tuniq - followed the same process as above - but as I had some marks on the base I started at lower grit - so I did in all 200,400, 600, 800, 1200 and 1500.
By the time I had finished my arm was ready to drop off but it was worth the effort and really unleashed greater OC potential so far I have gained 10-15C on each core (some of this could be attributed to pointing the TT in different direction to get push / pull air flow) and 300mhz in OC (aiming for 3600 stable tho - come on AS hurry up and dry)
I couldn't find anywhere that sold Iso Proprolyn (or whatever its called) so I just blew on the chip after each 30 strokes and each time I changed sand paper - rubbed the top of the cpu/cooler base with loo roll to remove any particles of dust.
After using 1500 grit a few times both the tuniq base and the cpu were reflecting back quite nicely - when I held them upto my monitor I could read back DELL in reverse perfectly.
I'm amazed how much difference this simple process has made - for anyone thinking of doing this I highly recommend it - its easier than you think - just read a few guides and a few YouTubes and then reap the rewards.
I'm over the moon
I'm over the moon
