Lapping Kit
I believe most people just buy a sand/glass paper kit from hardware stores. coarse - fine pieces, then just grab some glass from anywhere.
- Pea0n
i dont know if halfords is a competitor if it is please delete, but thats where u can get wet and dry paper from, i use dmy glass table but any glazer has a spare sheet for 2-3 quid
a good table will be fine tho wood or glass
Thanks guys, I'll head out at the weekend and get some. One question though, in this picture he's applying pressure to the bottom of the CPU on the pins.
I thought you weren't supposed to touch the bottom of the CPU?
That's fine but ideally you should put the black pins cover (one that comes with a retail box cpu) to eliminate all possibilities of static shock.
