Guys,
I'm using this guide to lap my TT. Unfortunately, I've run into a few problems. My TT is pretty flat, in fact, when i hold a razor blade over it, hardly any light comes through. I had read however, that if you bother to lap you CPU, then your HS better be flat otherwise you shouldn't even bother. So i decided to go forward with it.
Anyways, i started lapping by dripping some water over the 220 wet n dry. I then used a back and forth motion which immediately started to remove the grit from the paper. The HS was also sucking to the paper which is probably why the grit started to come off. From the below pictures, can anyone give me any suggestions.
As you can see, the heatsink has taken the grit right off!!!!! I only have another 3 sheets like this so any advice would be much appreciated!!!!
