lol do you have any t cut around? cause you could use some of that on cloth rubbing the cpu onto that one the chip was flat from the 600 to try and get a bit of a mirror shine but would be take a while possible, or a lot of t cut and you would have to give it a really good clean after to remove any chemicals from the t cut but i've seen that method used just the other day
lol
I think 600 is good stuff to have, but you will be lapping for a looong time. I used 240 grit on my TRUE and that took atleast 5 hours to get it flat, then another hour moving from 320, 400, 600 and finally 1200 to get it flat and shiny. Turned out pretty well and is very cool - 52 degrees load at 3.2 on C2Q 9550
i used 600 i think and 1200 grits, and had the cpu lapped flat + shiny within an hour, how the hell did you manage to spend 5 hours on getting the cpu flat? :|If you'd read my post or looked at the picture you will see I was lapping a 750g Thermalright Ultra Extreme Heatsink not a CPU.
Took me 3 1/2 hrs to lap my heat sink and about half an hour to lap my cpu .............. all nice n shiny though![]()
