mattup said:I would suggest 800 would be the min. Try and rub 2 pieces of 400 together, that will make them finer. Also ensure that you use water/oil when lapping.
3 in 1 or similar will do the trick.
Matt
l33t-krew said:Oil? Wtf! I thought oil was the worst thing that you could put on a heatsink.
Apparently it goes in the microscopic pores so the cooling is VASTLY inferior not matter what sort of cooling goes on it.
It would be the worst thing you could do.
COuld be wrong, but ill try and find a link![]()
Also get some finer stuff than that. My new lapping kit which should be arrivng goes up in the thousands, finished of with some gel which has an abrasion of 10.000
