- 15 Nov 2007
hi guys,i am thinking of lapping my akasa evo blue cooler and was wondering if the same process can be used on the actual cpu?if so how do i do this without killing it?,my q6600 is oc'd to 3ghz and running idle at 49c and running into high fiftys under load.also once i get the required finnish on the heatsink would it be worth using a cutting paste to hopefully get a better finnish?.also im using this cooler on the striker extreme m/b and had to litterally dismantle the cooler to attach it to the board due to the rediculously large heat pipe affair on the m/b,anyone got any tips on attaching this particular cooler to this m/b?i found it difficult to judge how tight the bolts were because of the lack of finger space if that makes sence.
