Lapping
22 May 2006
Glasgow
Hello im thinking of lapping my cpu however after a look around ocuk i dont see any lapping kits, would i be aswell just to go to B&Q and get the stuff there or is there any good kits that i could just order?
Cheers Dom
Depends how much you need to skim off, I just used 400 (or was it 600?) and 1200 grit, 400 to get the IHS almost levelled out and then the 1200 to finish off getting the last of the nickel sanded off.
I used a circular motion for the 400 grit rotating 90 degrees every few minutes and then just up and down for the 1200 again rotating every few minutes.
