Laptop advice
28 Feb 2004
North East, UK
Hi guys, I was wondering if someone could give me some advice on this Samsung R580 laptop? I've got a max of £600 to spend and I've seen this laptop for this price, managed to reserve the last one at a high street shop, I will be using it for general things as well as the odd bit of gaming, is it worth £600? Would be very grateful if someone could give me an answer today as I need to collect it if it's worth the asking price. Specs Bellow:
Thanks! :)
# Processor: Intel Core i3 Dual Core Processor 330M 2.13GHz
# Memory: 4GB
# HD Capacity: 500GB
# Display: 15.6"
# Graphics Card: Nvidia GeForce N11P-GE 512MB
# Optical Drive: DVD-SM
# Operating System: Windows 7 Home Premium
# Main Specification:
# Operating System: Genuine Windows 7 Home Premium
# Processor: Intel Core i3 Dual Core Processor 330M (2.13GHz) 3MB Cache
# Main Chipset: Intel HM55
# Memory System Memory: 4GB (2 x 2GB) DDR3 1066MHz
# Memory Slot: 2 x Slot SODIMM
# Display: 15.6" WCGA (1366 x 768) SuperBright Gloss LED Display
# Graphics: Nvidia GeForce N11P-GE 512MB
# Sound: HD (High Definition) Audio
# Sound Feaures: Mic noise Suppression / SRS 3D Sound Effect
# Speakers: 3 W Speakers (1.5 W x 2)
# Integrated Camera: 1.3 Mega Pixel Digital Motion Camera
# Hard Drive: 500GB SATA
# Optical Drive: 8x DVD-SM
# Communication: Wired Ethernet LAN (RJ45) 10/100, Wireless LAN 802.11 b/g/n / Bluetooth 2.1
# I/O Port: VGA, HDMI out, Headphone-out, Mic-in, Internal Mic, 4 x USB 2.0 (1x sleep-and-charge / eSATA combo), Express Card Slot 34mm, Multi Card Slot 3 in 1 Card Reader (SD, SDHC, MMC), DC-in (Power Port)
# Input: Keyboard Type: Island Keyboard With Numberic Keypad, Touch Pad (Scroll Scope, Flat Type)
# Security: Recovery Samsung Recovery Solution, Virus McAfee Virus Scan (trial version), Security BIOS Boot Up Password / HDD Password, Lock Kensington Lock Port
# Power: AC Adapter 60 Watt
# Battery: 6 Cell Lithium ion (4400mAh)
# Physical Dimension (W x D x H mm): 379.8 x 255.5 x 20.3 ~ 36.7mm
# Weight, include standard battery (kg): 2.6Kg
# Warranty: 1 Year Collect and Return
Thanks I ended up getting the model up from this which is the Samsung R780. Using it now and it's an excellent laptop. Nice and light especially since this is a 17" version, 1GB memory for the GPU which is the same as the model above, more power for the speakers as well. Very nice laptop and I would certainly recommend it. :)
4GB DDR3 and an i5 in a laptop for £600 is very good. That gfx card won't be great for high-end games though. It will handle most on low-mid settings I reckon.
Also picked up an i3 R780. The thing is huge, surprisingly please with the colour, which isn't at all as RED as I thought it would be.17" screen is pretty good and a nicely laid out keyboard, although the spacebar is doing my **** in, sometimes it just doesn't register a keystroke if you hit it near the edge.
