- 24 Sep 2007
USB C Hub, Docking Station, UtechSmart 11 in 1 Triple Display USB C Hub Dual 4K HDMI etc.
If it is compatible with your laptop, that will meet your requirements, and give the possibility of adding a third external monitor.
I think it is likely to work, but you will need to check your laptop meets the requirements. If you have Thunderbolt 3 that is a good start. I think you may need to check max data transfer rates from your laptop to see what monitor resolutions you can support, but I am not an expert here and can't tell you this.
