Laptop and USB stick encryption
5 Oct 2004
Notts
We have a client who would like to encrypt their laptops and USB sticks. They're only a small firm so don't need anything enterprise level.
What are you guys using?
We use Integral Encrypted USB sticks.
We prefer a hardware solution to a software one as we'd often have users delete the 'encrypted vault' file and then just use the stick unencrypted.
What version of Windows? If you dont need an enterprise solution then check your version of Windows as Windows 8 or Windows 10 pro comes with bitlocker which will encrypt your hard drives and memory sticks
As above, depending on how much you trust your users I'd personally recommend hardware level encryption. You're then not relying on users who will generally "forget" aka taking the easy way around.
