Laptop arm/stand.
11 Jun 2003
Sheffield, UK
Not QUITE directly laptop related.
Can anyone recommend a laptop arm/stand that is just the plate to sit it on, the arm and an adjustable clamp at the end of the arm (so it can go on an existing monitor stands desk pole/mount).
Can only seem to find ones with the whole mount/etc too, will go with a cheap one of those eventually and bodge a way to get it on my existing stand but was curious if anyone had seen one that was just the tray with some sort of adjustable grabby claw/bit at the end of the arm.
As an aside a lot of the cheap ones tend to not sit very flat, are a bit wobbly, etc. unless you do a bit of DIY on them yourself - I have a couple of Redbat branded ones that are cheap for that reason and I fixed myself.
