Laptop around £1000
12 Apr 2011
Looking to down size from my desktop due to the wife moaning at me takes to much room up.. so looking for a laptop around £1000 or less.. only to play WOW on at max and 60fps if possibly.. maybe can Spend a bit more if need be...
Thanks for any help
Thanks do you know if this one is good as well?!? Found it for £800 just not sure if I want to go 15in screen plus used to just 1440p and 4k going back to 1080p is ☹️bloody wifes..
Asus Strix 15In i7 8GB 1TB 256GB GTX1050Ti 4GB Ram.
you might struggle with the gfx side of it best bet is the 1060 to run it flat 60fps the one that Vargas put on looks to be spot on as it has the latest intel CPU yes its an i5 but it will handle WoW no problems
hi mate im looking to sell my gaming laptop..
8months old, mint condition all charger everything works fine.. paid £1100 from pc world.
windows 10
dell inspiron gaming 15 7000
intel i7-7700 @2.8ghz
16gb ram 2000mhz
1tb hdd
100gb ssd
nvidia GeForce GTX 1050ti
inbox me if interested
I have just bought Strix Scar edition on ***y. Brand new sealed close to your budget. 1070, 6 core i7 and 120hz ips screen. Worth having a look around
