Laptop Asking me Activate after resintalling window 8
13 Jul 2005
Hi Guy, I have a Asus S500CA laptop with windows 8 installaed and i made the mistake of installing the windows 8.1 beta which caused me alsorts of problems. I could not locate ny windows 8 key either on the laptop or in the packing then read online the key was kept in the bios so i reinstalled the whole thing from scratch an afte the installtion its now asking me to activate with a serial key (which i obviously dont have)
Does anyone know how i can resolve this ?
Not on a sticky label on the back, or in battery compartment? Is on my Alienware.
Plus also in bios so you really need a disaster for it to not auto activate.
yeah I know all this now guys thanks, lol
any idea how I can sort it though ? asus are a nightmare honestly im going in circles with them, any suggestions at all would be massively appreciated thanks
how can I get the oem version that was installed ?
When you first turned the laptop on it should have asked you to create a restore disc, or there would have been an option within the windows installation to create a restore disc.
You need this disc to restore the OEM install of Windows usually.
That's odd, I did a clean install of Win8 pro on my XPS 13 (cos the dell restore image was imo bad) and that activated straight away. I don't know if mine was an oem or retail DVD though
Same here when I installed windows for a friend on a new hard drive after the original one failed. I used my win 8 iso, the BIOS had the key stored and it activated immediately.
