Laptop Buying advice (Interface card question)
19 Oct 2003
At My Desk
Hi Everyone, I'm looking at buying a cheap dell laptop (Inspiron 1300) but the trouble is that the machine does not come with a PCMCIA slot, and has a "Pc Express port" or something, I've never heard of this type of port before and wondered if it was the new pcmcia replacement.
Now the problem is i have a pcmcia vodaphone 3G card and also a pcmcia wifi card which I use an external antenna with when I'm out on the field to get a decent connection to "the cloud wifi network" as my current acer laptop doesnt pick up wifi signals very well in the car, so I use a small external antenna most of the time connected to the pcmcia card.
So both of the cards i've got are going to be useless, but I was wondering if pc express slot is new, should i go ahead and buy it and buy a new wifi express card (if they are for sale) with an external antenna socket.
Or should i be sticking to laptops with pcmcia? what do you guys think?
Tigjaw said:
That seems to be a shop, you're bound to get he "No Competitors" post from the mods if it's not gone by the time they get here :)
You could always PM him the link.
1. Thats not a shop.
2. If it was you just quoted it. :p
3. The PM system is disabled.
You can plenty of usb>pcmcia adaptors.
