Laptop can't dial out over network.
19 Oct 2002
South London
Hello all i've just started using outpost firewall and the problem is that when i click Internet Explorer on laptop i'm not getting the auto dial coming up on my PC which has the broadband connection to the web, i can get web access but i have to connect to the web first with PC, have just changed over from sygate which worked ok i would click IE on laptop and dial up box would come up on PC and i would have access to web PC is setup to allow Internet connection sharing with all box's ticked.
PS All PC's are showing up on wi-fi network and file sharing is ok.
It's good old tiscali with sagem modem which you still have to dial out for broadband connection it's not always on. If i disable outpost it works ok plus if i use sygate there is no problem, wi-fi network is setup as adhoc if that helps.
