Laptop charging in car?
5 Mar 2003
Swadlincote
Can i charge my laptop up in the car using the cigarette lighter socket?
Is there something i can buy to enable this?
TIA
Doosht
You don't necessarily need an inverter - why bother converting 12v DC to 240v AC then back to ~19v DC? Wasteful!
You can get specific in-car chargers for many makes/models of laptops - but they're likely to be sold by competitors, so will not be able to link... a Google search with your laptop make and "in car adapter" should yield some results.
trouble is, those laptop specific doodles cost more than an 150w inverter which ive seen for £19.99 and would suit any laptop due to the fact that the end is just a normal 3 pin plug
