Laptop Cooler for 19inch Laptop
10 May 2004
East Yorkshire, UK
Hi
I am looking for a Laptop Cooler that can accommodate a 19inch Laptop. My Studio 17 is getting ridiculously hot. I have had a look (Logitech N100 and Zalman ZM-NC1500); but they only seem to accommodate up to 17inch. Anyone used these on a 19inch, or know one that will work?
Cheers
Hi, I have a Cooler Master NotePal U2 for my dell studio 17. The laptop is about 2-3" wider than the cooler but the fans are easy to move so it dose the job.
I tried 3 different makes, one of the issues is they slide off the front due to the studio's tapered frontal.
TBH raising the back with just some table mats now as it does the job, in fact it is better then the last 1 tried (ENERMAX CP001G-B) as that fan did not get close to the intakes.
Not seen 1 yet wide enough to do a proper job.
Hi
Cheers
the zalman 1500 is fine with my 18.4 in laptop
the laptop intakes are right over the fans on my acer
I use a Zalman ZM-NC2000 with a HP Pavilion dv-8 (18.4" screen), hangs over about 1cm on the sides but works fine.
First thing to do (assuming you havent done it allready) is to blow into the cooling fins of the laptop (mouth should do), and blow any dust out through the fan vents.. that should help with the cooling (you might have more than 1 fan)
PS.the best laptop cooler is the Zalman 2000..You could make your own using the zalman principle, its very effective.
I use a kobalt G870 17" Laptop on a zalman 1500 cooler and it just about fits for the fan positions.
