Laptop cooling mats - any recommendations?
Any cooling mats I've come across personally are "one size fits all", so you would use the same mat for any size laptop.
There should be no danger of it blocking any fan vents or causing damage to the laptop - if it covers the bottom of a 15" completely and doesn't block anything, why would it block anything on a laptop it doesn't completely cover? :)
Laptop processors, which are the main source of the machine's heat, are usually right at the center of the laptop base. So, as long as you keep the mat centered, you should be fine.
Thanks for the advice, I ordered that one from ocuk and took advantage of their free delivery, will get it sent out to Prague tomorrow.
When did you place your order mate? It's now showing as out of stock.
Was planning one of these myself. Reviews have been good! :)
