Laptop CPU - Upgradable?
1 Dec 2005
Stoke on Trent
What are the chances that the Celeron-M in my lappy can be swapped out for a beefier Pentium-M ?
It just feels sluggish compared to my desktop which is either due to only having 256Mb RAM ( got another 256Mb on its way ) or its the CPU.
If they use the same socket, then there's probably a good chance.
Drop the manufacturer an email or check their website to see what cpu's the lappy can take.
Remember though, laptops also run on a lower fsb than most desktops, so that could be a factor as to why it feels more sluggish.
You're also using a dual core CPU which can lead to windows feeling far 'snappier' than on a single core CPU
The ram probably is the biggest culprit though :)
