Laptop CPU upgrade questions!
12 May 2011
Southampton
I wish to upgrade my laptop's CPU. I currently have a HP dv3-4100sa, with an Intel P6100. The procedure is outlined in the service manual. The service manual says the MB supports:
Intel Core Quad i7-840QM 1.86-GHz (1333-MHz FSB, 8-MB L3)
Intel Core Quad i7-820QM 1.73-GHz (1333-MHz FSB, 8-MB L3)
Intel Core Quad i7-740QM 1.73-GHz (1333-MHz FSB, 6-MB L3 cache)
Intel Core Quad i7-720QM 1.60-GHz (1333-MHz FSB, 6-MB L3 cache)
Intel Core Dual i5-580M 2.66-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Dual Core i5-560M 2.66-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-540M 2.53-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-520M 2.40-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Dual Core i5-480M 2.66-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-460M 2.53-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-450M 2.40-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-430M 2.26-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-390M 2.66-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-380M 2.53-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i5-370M 2.40-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Core Dual i3-350M 2.26-GHz (1066-MHz FSB, 3-MB L3 cache)
Intel Pentium P6300 2.26-GHz processor (1066-MHz, 3-MB L3 cache)
Intel Pentium P6200 2.13-GHz processor (1066-MHz, 3-MB L3 cache)
Intel Pentium P6100 2.00-GHz processor (1066-MHz, 3-MB L3 cache)
Intel Core2 P6000 1.86-GHz processor (1066-MHz, 3-MB L3 cache)
I am only looking at the i3 and i5 processors as they have the same FSB (considering RAM...) and TDP (35 watts). I am thinking i5 480m as it seems pretty cheap (~£50) and the others are harder to find used, and would be a big CPU performance increase (right?). So:
Will my laptop overheat if I use a 480 (without turbo enabled)?
I have to get shared/joint video drivers off the HP website, as my laptop has Intel HD + ATI 5470. The i5 480 has a higher "dynamic" clock rate for the built in Intel graphics compared to my P6100 (766 vs 667 MHz, both 500MHz base). Will the shared drivers still work?
Cheers!
Should see some increase in performance, especially with the extra core, but I would expect the temps to increase as well.
As for the GPU drivers, you can just use the drivers off the Intel and AMD site.
What extra core? Both are Dual core cpus. The i5 does have HT though which may help a little, definetly will be faster but not sure in 'day to day' usage so much. Temps will probably be a tad higher loaded but nothing drastic.
Whoops, getting my CPUs mixed up :rolleyes:
