Laptop cracked
8 Feb 2006
Stafford
hi all
my mates laptop lid is cracked around the hinges,
so every time you open or shut it, it cracks more
any suggestions on how to fix it???
valerian said:
hi all
how old is it? warranty?
basmic said:
Glue.
How else do you expect to fix it?
i doubt glue would do the crack
however i was expecting someone to say glue something over the crack, to bridge it
the type of glue was an issue as well, i are'nt sure super glue is the answer
Usually there is a screw adjustment to loosen the lid clutch so it opens more easily. Ease this off a bit and it will reduce the stress and hopefully stop the cracking. I's then superglue the crack with a fresh tube of glue (not some old, weathered crappy stuff).
[J]
