I'm looking to get rid of my current rig, which is a toweris
Core i5 2500k 3.3ghz
8GB DDR 2 RAM
SATA Hybrid Drive
Radeon HD 6800 1GB
Now I've had this machine for a good few years and have moved into my own house. The reason I want a laptop replacement is that I work as a 3D designer and I'm looking to learn new skills but don't want to be locked away in one of the bedrooms (where my PC currently is), as I have 2 dogs and want to be around them, so I'm ideally looking for a desktop replacement. I don't care if it weights a tonne either.
I'd ideally want a 17" laptop which will perform better than my current rig for the best price possible. I was hoping you guys could link me to the best laptops out there that meet my needs. I'll mainly be using 3D Studio max on the laptop and doing modelling and rendering on. The main thing is that it can cope with a decent amount of polygons on the screen without slowing down and crashing.
The machine I use at work is:
i7-3770 3.4ghz
16GB RAM
128GB SSD Drive
GTX 560Ti 2GB
Basically I'm looking for a laptop to replace my home desktop, one that a step up from my current rig but also a close to my works rig spec as possible for the best price. Ideally sub £1000 if possible.
8GB DDR 2 RAM
SATA Hybrid Drive
Radeon HD 6800 1GB
i7-3770 3.4ghz
16GB RAM
128GB SSD Drive
GTX 560Ti 2GB
So does that mean from that link I would need a laptop with the 870m graphics or higher for me to see a performance boost on what I already have at home?
