- 5 Sep 2011
- Nottingham, UK
Hey Y'all,
My mate has a problem with his HP Pavilion laptop... not sure what the model is.
Its an AMD Turion Dual Core at 2.1ghz 2gb DDR2 memory and 250GB HDD running Win 7.
Basically the laptop refuses to boot. Turn it on, lights come on for a second then turns itself straight off again.
I have removed the battery and used the charger alone, tried a different charger, tried with the battery in, taken it apart and checked the CPU, MEMORY and HDD (all seem fine) and no damage to the mobo from what I can see.
I have swap tested e.g. used one stick of memory in at a time just to be on the safe side, booted without HDD in... I am stumped.
Any ideas??? Or is it just dead.
Thanks
Cinderz
Thanks
Cinderz
