Laptop fan
28 Jul 2003
The Moon
I need a new cpu fan for my laptop and was wondering if anyone on here knew where I could find a shop that sells/specialises in them. :confused:
sorry mate well not sure if u can get these :D hopefully someone could help u with that, i think when they go that is kinda it. spose u could buy one the the laptop cooling pads u can get from akasa or coolermaster, which might help a bit.
Someone told me that it is possible to replace the cpu fan on a laptop, there must be some website/shop that specialises in this?
I got one that came out of my old laptop if you need. Dunno if it will fit but your welcome to it if you need. Drop me a line in msn if you need and will send you a couple of picts
