Laptop for csgo
14 Nov 2012
Hey so i need a laptop that's going to give me at least 150-200 fps in all conditions in csgo for lanning events to not have problems budget is not a problem as i will get it on finance.
CS;GO will be the main game i play on it as i need this for lan events.
Can anyone explain why some of the overclockers built laptops seem 10x better then branded ones but cheaper
These laptops use Clevo chassis which are built to order, and are cheaper.
The named Branded Laptops from Asus, Gigabyte and MSI mean paying for the name and branding.
need a laptop with a 780m gfx and a dvi slot for my monitor to be plugged in
A laptop with a A GT 740M will play @ 54 fps 1080p Ultra.
GTX 660M @ 88.5 fps 1080p Ultra.
GTX 760M @ 98 fps 1080p Ultra.
GTX 765M @ 106 fps 1080p Ultra.
GTX 770M @ 150 fps 1080p Ultra.
GTX 780M @ 190 fps 1080p Ultra.
All information was taken from Notebookcheck.
The most you would see is 60 fps on an external monitor due how it is controlled by the intel GPU interface to the DVI port.
So no need to get a GTX 780M unless you wish to future proof.
The money you would spend on a laptop with a GTX 780M would easily cover a small desktop.
