- 17 Dec 2015
I'm looking to buy a new laptop which will almost exclusively be used for Adobe Lightroom, which works best with lots of cores (when importing and exporting images and generating 1:1 previews), and a fast single core clock speed when editing.
I've read through most of the threads in this forum and I see there's a lot of love for the Legion 5 Pro, but availability seems to be an issue, and some reliability issues with poor support. I tried the Lenovo site to check the configuration options, but it's not even listed any more so assume they have sold out of their next allocation of stock.
Another option that came to my attention was an Asus Strix G15 (G513QM-HF120T), which is currently available for £1099.
It comes with the 5900HX processor instead of the 5800H, but both are 8 cores and a marginal difference in clock speed.
The display is 1080p, but 300Hz and 100% Adobe RGB. Not as bright as the Lenovo though, but it will never be used outside.
It has a 3060 instead of the 3070, but as it's not going to be used for gaming this isn't a concern.
Same 16Gb of RAM, but no option to upgrade at the time of buying - would need to buy 32Gb or 64Gb if I wanted to upgrade.
512 SSD instead of 1TB, but I'd likely upgrade this anyway.
Has anyone got/used one of these Asusu Strix G15 models and got any feedback on the screen, keyboard, battery life, reliability etc based on real life use.
Any feedback or advice would be greatly appreciated
