Laptop for work
Caporegime
13 Jan 2010
Llaneirwg
I require a work laptop and haven't really looked at such things for years
Needs 1080 screen
15 or more inches
Must be 64 bit
8gb ram or more
I7
Number pad
Doesn't need to be light
The screen and ram are main priority
In not sure of the price range Tbh nor how much is the minimum
GIGABYTE P35K - 1080p with IPS display and sufficient 8gb RAM should do a good job
That is even better, the weak point being the gpu and touch pad,. Seeing as I really need the cpu and ram and will always use a mouse I don't see this as a problem
I might put this one forward
The p35k is the one I am going to push for.
Between ultra book and desktop replacement
Good cpu
Decent amount of ram
Oh joy of joys it will not be a network crippled machine
