Right guys im compleatly stuck ere and need a bit of help please !
It’s a strange one I have a Asus Zephrus with a 8750H and a gtx 1070 144hz monitor.
I travel allot because of work etc and play Destiny 2 a far bit always been into overclocking’s PC etc so I tend to monitor how the laptop runs. The thing runs hot but doesn’t really thermal throttle that much and ive had it running pretty solid for the last 2 years.
3800mhz-4000mhz CPU
1860mhz -1900mhz GPU
I normally get between 70-125FPS
GPU usage when I don’t have the problem 99%
CPU usage is around 40- 65%
Recently I will log into the games FPS is fine when it goes to a cut seen or I alt tab or but bring up a menu screen the FPS half’s and then stays like that until a reboot. Same in destiny 2 and borderlands 3.
CPU usage stays the same 40-65% as does clock speed
GPU usage 35-50% clocks rate 1455mhz
power around 60 wats normal is 100-110
temp drops to around 70 normal 80 ish
FPS 30-50
I have tried;
Safe mode DDU reinstall divers, the same with older drivers.
System restore to a couple of weeks back to undo windows updates.
Changed all the relevant setting in Niva control panel , slider to max performance , low latency modes, power mode to prefer maximum performance., shader cash off.
If i pull the power out when it gets stuck into the low GPU power mode it resets it. doesn't last for that long tho...
I am now out of ideas any help would be great I really don’t want to have to wipe the laptop….
Cheers guys
3800mhz-4000mhz CPU
FPS 30-50
I have tried;
Cheers guys
