Right, got this laptop with some files I want to backup onto my other machine on the network. Decided to hook it up to router through Ethernet port (wired). According to the Router, its assigned 192.168.0.126, but for some reason on the laptop under Local Area Connection Status its showing 172.22.3.198
Obviously nothing is working, i.e. File Sharing nor net. Tried cable on other machine & seems fine (otherwise you wouldn’t be getting this). Laptop's WiFi works fine & is getting the right address, 192.168.0.126, etc.
Could the Ethernet port be em, knackered? See it's hardly ever been used (e.port), but laptop is mostly out on the 'field'. Any advice will be appreciated
Obviously nothing is working, i.e. File Sharing nor net. Tried cable on other machine & seems fine (otherwise you wouldn’t be getting this). Laptop's WiFi works fine & is getting the right address, 192.168.0.126, etc.Could the Ethernet port be em, knackered? See it's hardly ever been used (e.port), but laptop is mostly out on the 'field'. Any advice will be appreciated
