hello on my laptop (Toshiba p850-30v) it runs 2 gpus (intel 3000 and gt630m 2gb) when i am using the Intel 3000 it will run all day no temp increase (idles around 40c to 50c) go to use the gt630m it will go up to 93c ive applied new thermal paste (cooler master e1 ic essential) and cooper shims for both the processor and gpu but the temps dont change (tested before i got the coper it did the same thing) ive used fur mark to test how quick the temps rose (without the fur circle thing on) it takes about 4 minutes to go from idle (45c to 51c) to 93c but with the fur circle (making the gpu load run at 99% instead of about 60ish%) it takes about 30 seconds to reach thermal limit (93c) the laptop is on a cooling pad as well but with or without the pad it makes no difference
