- 26 Apr 2004
- Milton Keynes
Hi guys, was wondering if you could help me chose a laptop.
I have up to about £700-750MAX to spend. I do intend to play games on it as well as do work, so all round system performance and gfx performance are important to me.
Obviously if you can spec some choices that might be appropriate but less expensive then that would be good too!
