- 3 Aug 2013
hi guys i dont post much am going to start using forum more
basically my friend has brought me there acer aspire e1-571 which they spilt tea on by the touch pad and the screen went funny it then once turned on would turn the power light on hdd spins and turn straight back off and on again in a loop with a black screen
ive stripped it cleaned it and left at room temperature for two days gone to boot and it booted so went on factory reset and its gone back to same state black screen turning on and off again with black screen where was a slight bit of contact on the board which i cleaned near the touch pad ive cleaned that if i give it a good blow around the chips that were affected it will boot again but once off does the same again its really puzzled me
my next step will be to throw some heat on it around that area with my solder station hot air gun what do you guys think its driving me nuts phoned me mate up aswell he was well chuffed now im back to square one thanks
any help will be apreciated thanks
