- 8 Sep 2005
- Chichester
Im a PC person, don't know much about laptop hardware, so need some help. I've always prefered AMD, but i heard intel are better now?
Anyway which one of the following would you consider a better spec, both pretty much the same price. Graphics card, and processor, which ones are better?
-Intel Centrino Mobile Technology with Intel CoreT Processor Solo T1350 1.86Ghz 2MB L2 Cache
- 15.4" WXGA Widescreen Panel (1280x800)
- 1024MB DDR2 Memory (2x512MB)
- Intel GMA 950 Media shared graphics memory upto 256MB
- 60GB 5400rpm IDE Hard Drive
- Internal Combo 24x CDRW / 8x DVD-ROM
- Internal 56k V.92 Modem
- Intel ProWireless 3945 802.11a/b/g Mini PC Wireless LAN
- Microsoft WIndows XP Home SP2 Edition Installed and supplied
- PC Restore system supplied free by Symantec
- Microsoft Works 7.0
- 1yr DELL collect & return warranty (Call DELL on 0870 9080800 and have the work number from the original packaging handy)
OR
15.4" X-Brite Screen
AMD Turion 64 X2 Tl-52 1.6GHz Socket 1 Processor
1024MB DDR2 667MHz Memory
80GB SATA Hard Drive
ATI RS485 High Performance Graphics
7.1 Azalia High Definition Audio
DVD/RW Multi Burner
56K Internal Modem
10/100 LAN & 54G Wireless LAN
Thanks
OR
DVD/RW Multi Burner
56K Internal Modem
Thanks
