Hi,I currently have a sony Viao VGN-FS415E which has 512 Memory Type SO-DIMM - 533Mhz (DDR2) installed.
Slot 1 : 512 Mb
Slot 2 : Empty
The laptop will take 2gb max and i would like to buy the max 2gb,But on ocuk
only do 1gb DDR2 PC2-4200C5 200-Pin SODIMM Modules running at 533MHz RAM Speed.
The question is would it be possible to put in Crucial 2GB (2x1GB) DDR2 PC2-5300C5 200-Pin SODIMM Dual Channel Kit (CT2KIT12864AC667)
2x 1GB, 667MHz RAM Speed, CAS 5, 1.8v SODIMM, Unbuffered, Non-ECC, Lifetime Warranty with Crucial.
So basically can i run 667mhz ram in a laptop that takes 533mhz ram.
Slot 1 : 512 Mb
Slot 2 : Empty
