Laptop Memory Compatibility
5 Jan 2018
Hey,
I have a Toshiba Satellite P70-B-10T and im going to be doing some software testing using different types of Memory and im wondering if anyone knows what other types of memory would be compatible with this Laptop? I cant seem to find any information on Toshibas website regarding the motherboard/circuit and all it says about the memory in it is the following:
standard : 16,384 (8,192 + 8,192) MB
maximum expandability : 16,384 MB
technology : DDR3L RAM (1,600 MHz)
Is there anything like memory compatibility table so you can see if DDR$L 1,600 MHz works then so should this this this and that?
As this is for testing only i wont be buying the memory new nor will i want to pay a lot for the memory, i only need like 2 x 1GB sticks. I did buy 2 x 1GB 2Rx16 PC3-10600S 1333MHz DDR3 for £3.78 from eBay but they dont seem to be compatible with my laptop as as soon as i press the power button it turns off straight away.
Any help would be great.
Thanks
I just gave 'Toshiba Satellite P70-B-10T compatible memory' a google and all the RAM manufacturers websites come up listing their compatible RAM with this laptop.
Try doing that same search
