Laptop memory, mixing types?
27 Feb 2006
Normanton
Hi,
I have a packard bell easynote F5280 laptop, i have opened it and the memory it has currently is the following PC2700, 256mb DDR 333 CL2.5.
Would i be able to add this type of memory (see below)
NT256D64S88AMGM - 7K
256MB DDR - 266MHz - CL2
PC2100S - 20330
Thanks
Depends on the speed of your CPU, if its a 400mhz FBS chip, then you should be ok.
But you'd be better off finding some PC2700 memory, as you'd be losing a little performance putting PC2100 in there.
