- 25 Mar 2006
- Thornbury
i have a cheap advent 7000 laptop, i want to upgrade the ram and possibly the cpu, i need to buy second hand as im not working so on a budget, i have no idea what i should be looking for.
the laptop has 2 slots and has 1 x 256mb module, so should i buy 1 module to replace this or should i add a module and keep the existing module? should i go for 1gb of ram ?
the memory in the laptop has these numbers on it 2LE1RM00267 TFC0542
LAPTOP SPEC HERE
i would like to upgrade the cpu too but im not sure what is the biggest cpu i can instal
LAPTOP SPEC HERE
