27 Aug 2020 at 10:13 #1 LemonAech LemonAech Associate Joined 27 Aug 2020 Posts 2 Can I use 8gb DDR4 2400 memory with an existing 8gb 2400T stick to make 16? Or is the 2400T only compatible with other 2400T sticks?
27 Aug 2020 at 10:24 #2 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,113 Location Dundee The T just means that it is cl17 ram so as long as the stick you are adding can run at cl17 it should work fine together.
27 Aug 2020 at 10:26 #3 LemonAech LemonAech Associate OP Joined 27 Aug 2020 Posts 2 chipps101 said: The T just means that it is cl17 ram so as long as the stick you are adding can run at cl17 it should work fine together. Click to expand... Ahh I see, thanks for getting back to me. The 2nd stick just says 2400. No real way to tell if it'll run at cl17 I guess?
27 Aug 2020 at 10:50 #4 chipps101 chipps101 Soldato Joined 8 Jan 2010 Posts 4,113 Location Dundee You can try googling the part number of the other stick and see if you can find the spec sheet on it
