Laptop not detecting hard drive.
28 May 2007
Saturn’s moon Titan
hi my kids laptop isn’t showing the hard drive in the bios it won’t boot into windows . Things I’ve tried are checking the bios it’s not showing . The laptop is a Packard bell model number ms2274 I think. Any help would be appreciated. Thank you .
Regards scubes.
It is likely to be one of several things:
1) Failed hard drive (most likely)
2) Faulty or loose har drive cable/connection
3) Faulty motherboard
The hard drive itself is most likely assuming it's an old spinning hard drive. I would suggest chexking whether it's a SATA drive (most likely) or IDE (unlikely) and get a USB to hard drive connector to test the drive in another system. If it is faulty then it's replaceable.
