laptop ok for WoW ?
19 Feb 2007
Sol
Ok so my new laptop is in the middle of installing WoW but as i havent played for around a year i was wondering how it will cope with any graphical updates etc...
I would really appreciate any input :)
Specs:
CPU: AMD Athlon(tm)X2 DualCore QL-66 (2 CPUs), ~2.2GHz
RAM: 4GB DDR2
GPU: ATI 3200 512MB integrated
HDD: WD Scorpio Blue 500GB
OS: Windows 7 Ultimate 64Bit
imagine it would be fine, maybe putting a few of the settings down a bit. i mean my old laptop was rubbish and it could play it with everything at lowest and yours is much better spec than it, i mean mine had only 128mb of shared memory for graphics :p
It's fine - don't expect stellar performance, but you should be able to raid on it quite comfortably. Just turn off V-Sync and shadows if it's struggling, tweak the other graphics sliders as desired.
