- 7 Oct 2009
Hi
I have a Asus G1S 2ghz Core 2 Duo,2gb Ram, 8600m gt, 160gb hdd. Now i have noticed it recently when i take it off the cooling pad it begins to heat up very quickly, I have also noticed that it is starting to run sluggish, I reinstalled vista but still the same.
So what can i do about it heating up, Can i turn the 8600 off and just use onboard or is that not possible?? and also what can i do about it running slow, more ram, win 7?
I have it on the lowest battery setting possible while on battery with max cpu usage at 20% i think this could be causing it to run slow. But the most important thing is the heat.
Thanks guys
Thanks guys
