I've noticed that my laptop likes to change fan speeds really quickly, up and down, so I checked out temperatures on SpeedFan. After a few hours of use the best temperatures idle I could get was (from what I remember) GPU: 73, CPU 1 & 2: 51. That is with the window open having a breeze directly behind the laptop when elevating it from the desk. On startup the temps are running between GPU: 68 CPU: 47-48 and I have noticed green ticks on the CPU value at that but flames on the GPU.
Last time I sent my laptop to Asus for a similar overheating problem and all they did was change the HDD. I have upgraded the HDD and installed Windows 7 since then, and have noticed that the area where it is stored is the only part that is getting pretty hot to touch compared with the rest of the laptop. The fan speed change is really annoying and it can get quite loud if I'm thinking of taking it on the train or something.
Could a faulty HDD cause high component tempertures and could it be solved by switching to a spare HDD?
Thanks
Thanks
