Laptop power question.
15 Apr 2006
Scotland
I have a Dell MX1210 and im away to Brazil for a few months, i know that Brazil gives the same mains power as the US so 110volts.
Does anyone know of an easy way i can uses my laptop over there without any problems, do i have to buy a US adaptor? or just get one of those voltage controllers.
Any help would be a big help.
Cheers :)
Cheers :)
The Brazilian authority has mandated that from 31 December 2006, plugs for Brazil need to comply with NBR 14136.
so if your going before 31st of Dec, you should be ok with a US adaptor id of thought :p
